주요 콘텐츠로 건너뛰기
APC Smart-UPS SC 450VA Battery Replacement
필요한 것
  1. APC Smart-UPS SC 450VA Battery Replacement, Remove the faceplate: 1 단계, 이미지 1개 중 1개
    • Pull on the left corner of the faceplate to remove it.
  2. APC Smart-UPS SC 450VA Battery Replacement, Unscrew the battery cover: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Use a PH2 screwdriver to unscrew the 4 screws securing the battery cover.
  3. APC Smart-UPS SC 450VA Battery Replacement, Remove the battery: 3 단계, 이미지 2개 중 1개 APC Smart-UPS SC 450VA Battery Replacement, Remove the battery: 3 단계, 이미지 2개 중 2개
    • Use the pull tab to pull out the battery.
    • Be sure to not pinch the cables between the case and the battery.
    • Unplug the battery connector.
    • Remove the battery.
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals.
결론
작성자
2다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
31,157 평판
안내서 71개를 작성함
4가이드 댓글
this is incorrect, since 1995 all Smart UPS have hot swappable batteries. no need to turn it off, that's the whole point of it being in the front of the device - https://www.apc.com/us/en/faqs/FA303216/
Ryan Matthews - 답글
Thank you, the guide has been adjusted.
Sebastian -
After hot swapping the battery replacement my replace battery LED is still lit. How do I reset that?
Michael Dickson - 답글
You can press and hold the power button for a few seconds to manually run a self-test or just wait until it reaches the next scheduled self-test (every 7 or 14 days depending on configuration). It is recommended to wait at least 24 hours before performing the self test as the new battery needs time to reach capacity.
Sebastian -
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 65
지난 30일: 250
전체 시간: 8,255
