주요 콘텐츠로 건너뛰기
APS Tech 101629 Channel Switch Replacement
필요한 것
  1. APS Tech 101629 Channel Switch Replacement, External Casing: 1 단계, 이미지 1/3 APS Tech 101629 Channel Switch Replacement, External Casing: 1 단계, 이미지 2/3 APS Tech 101629 Channel Switch Replacement, External Casing: 1 단계, 이미지 3/3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 Channel Switch Replacement: 2 단계, 이미지 1/2 APS Tech 101629 Channel Switch Replacement: 2 단계, 이미지 2/2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 Channel Switch Replacement: 3 단계, 이미지 1/2 APS Tech 101629 Channel Switch Replacement: 3 단계, 이미지 2/2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 Channel Switch Replacement: 4 단계, 이미지 1/1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 Channel Switch Replacement: 5 단계, 이미지 1/2 APS Tech 101629 Channel Switch Replacement: 5 단계, 이미지 2/2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 Channel Switch Replacement, Channel Switch: 6 단계, 이미지 1/2 APS Tech 101629 Channel Switch Replacement, Channel Switch: 6 단계, 이미지 2/2
    • Find the conjoined ID cable wires that are colored black, orange, and yellow.
    • Lift white portion of cable wires to disconnect it.
  7. APS Tech 101629 Channel Switch Replacement: 7 단계, 이미지 1/3 APS Tech 101629 Channel Switch Replacement: 7 단계, 이미지 2/3 APS Tech 101629 Channel Switch Replacement: 7 단계, 이미지 3/3
    • At this point, the fan is loose and can be easily moved but not disconnected.
    • Using the spudger, depress the pressure holders at all four corners of the fan.
    • Take out the fan and its cords, by pulling it outward from its cavity within the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alexis Weckel
회원 가입일: 04/11/11
140 평판
안내서 3개 작성하였습니다
Cal Poly, Team 24-60, Amido Spring 2011 Cal Poly, Team 24-60, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G60
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 633
