주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
APS Tech 101629 Power Switch Replacement
필요한 것
    1. APS Tech 101629 Power Switch Replacement, External Casing: 1 단계, 이미지 3개 중 1개 APS Tech 101629 Power Switch Replacement, External Casing: 1 단계, 이미지 3개 중 2개 APS Tech 101629 Power Switch Replacement, External Casing: 1 단계, 이미지 3개 중 3개
      • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
      댓글 쓰기
    2. APS Tech 101629 Power Switch Replacement: 2 단계, 이미지 2개 중 1개 APS Tech 101629 Power Switch Replacement: 2 단계, 이미지 2개 중 2개
      • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
      댓글 쓰기
    3. APS Tech 101629 Power Switch Replacement: 3 단계, 이미지 2개 중 1개 APS Tech 101629 Power Switch Replacement: 3 단계, 이미지 2개 중 2개
      • Flip the device right side up.
      • Gently slide the casing upwards and off the hard drive.
      댓글 쓰기
    4. APS Tech 101629 Power Switch Replacement: 4 단계, 이미지 1개 중 1개
      • Flip device upside down again.
      • Gently pry the bottom gray casing away from the device.
      댓글 쓰기
    5. APS Tech 101629 Power Switch Replacement: 5 단계, 이미지 2개 중 1개 APS Tech 101629 Power Switch Replacement: 5 단계, 이미지 2개 중 2개
      • Rotate so the back of the device is facing you.
      • Gently pry the back casing away.
      • When the back casing is removed, the fan will become loose.
      댓글 쓰기
    1. APS Tech 101629 Power Switch Replacement, Channel Switch: 6 단계, 이미지 2개 중 1개 APS Tech 101629 Power Switch Replacement, Channel Switch: 6 단계, 이미지 2개 중 2개
      • Find the conjoined ID cable wires that are colored black, orange, and yellow.
      • Lift white portion of cable wires to disconnect it.
      댓글 쓰기
    2. APS Tech 101629 Power Switch Replacement: 7 단계, 이미지 3개 중 1개 APS Tech 101629 Power Switch Replacement: 7 단계, 이미지 3개 중 2개 APS Tech 101629 Power Switch Replacement: 7 단계, 이미지 3개 중 3개
      • At this point, the fan is loose and can be easily moved but not disconnected.
      • Using the spudger, depress the pressure holders at all four corners of the fan.
      • Take out the fan and its cords, by pulling it outward from its cavity within the device.
      댓글 쓰기
    1. APS Tech 101629 Power Switch Replacement, Power Switch: 8 단계, 이미지 2개 중 1개 APS Tech 101629 Power Switch Replacement, Power Switch: 8 단계, 이미지 2개 중 2개
      • Depress 2 pressure holds on each side of the power switch.
      • Press out the back of the device.
      댓글 쓰기
    2. APS Tech 101629 Power Switch Replacement: 9 단계, 이미지 2개 중 1개 APS Tech 101629 Power Switch Replacement: 9 단계, 이미지 2개 중 2개
      • Remove all four 4 connections from the power switch.
      • Remember that the straight connections are on the far side, while the L-shaped connections are on the near side, and that both yellow connections are on top. This is helpful for reassembly.
      • These are very hard to get off, use patience and wiggling.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Alexis Weckel
회원 가입일: 04/11/11
140 평판
안내서 3개를 작성함
Cal Poly, Team 24-60, Amido Spring 2011 Cal Poly, Team 24-60, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G60
5 회원들
안내서 48개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 42
전체 시간: 1,045
