소개
The guide will teach you how to replace any faulty SCSI Connections at the back of the device. It requires the case to be opened, so any warranties covering the device will be voided.
필요한 것
Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
Flip so device is upside down.
Remove 4 screws with Phillips #1 screw driver.
Remove the four Phillips #1 Screws from back panel.
Once the screws are removed, the two connections are easily removed from the body.
거의 끝나갑니다!
결론
