이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
Flip the device right side up.
Gently slide the casing upwards and off the hard drive.
Flip device upside down again.
Gently pry the bottom gray casing away from the device.
Rotate so the back of the device is facing you.
Gently pry the back casing away.
When the back casing is removed, the fan will become loose.
Flip so device is upside down.
Remove 4 screws with Phillips #1 screw driver.
Slide the internal drive component away from the back of the device.
Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
Audio Connection
SCSI ID
Terminate On
SCSI Connection
DC Input (power)
Remove the four Phillips #1 Screws from back panel.
Once the screws are removed, the two connections are easily removed from the body.
