주요 콘텐츠로 건너뛰기
Aroma ARC-914SBD Lid Replacement
필요한 것
  1. Aroma ARC-914SBD Lid Replacement, Lid: 1 단계, 이미지 1/2 Aroma ARC-914SBD Lid Replacement, Lid: 1 단계, 이미지 2/2
    • The first step is removing the condensation catcher in order to reach the control panel. We do this by pinching the condensation catcher as shown, on both sides and pull the condensation catcher away from the cooker.
  2. Aroma ARC-914SBD Lid Replacement: 2 단계, 이미지 1/1
    • Once the condensation catcher has been removed, set it aside for reassembly later.
    • Now make sure you have a a Phillips head screwdriver, size PH2. This tool will allow you to remove the screw that was behind the condensation catcher.
  3. Aroma ARC-914SBD Lid Replacement: 3 단계, 이미지 1/2 Aroma ARC-914SBD Lid Replacement: 3 단계, 이미지 2/2
    • Gently remove the piece that was held in place by the screw, you do this by pulling out from the top, then pulling up. This will expose the hinges for the lid.
  4. Aroma ARC-914SBD Lid Replacement: 4 단계, 이미지 1/3 Aroma ARC-914SBD Lid Replacement: 4 단계, 이미지 2/3 Aroma ARC-914SBD Lid Replacement: 4 단계, 이미지 3/3
    • To remove the hinge, gently rotate the bottom of the rod upwards, then push inward to pull the rod out. Repeat the process for each rod. This will allow the lid to be removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brandon Nieves
회원 가입일: 09/04/15
956 평판
안내서 8개 작성하였습니다
USF Tampa, Team 2-3, Sullivan Fall 2015 USF Tampa, Team 2-3, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S2G3
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
Where can you buy a replacement lid?
Cristian Ortiz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 24
전체 시간: 2,135
