주요 콘텐츠로 건너뛰기
ARRIS Surfboard SB6183 Modem Heatsink Replacement
필요한 것
  1. ARRIS Surfboard SB6183 Modem Heatsink Replacement, Heatsink: 1 단계, 이미지 3개 중 1개 ARRIS Surfboard SB6183 Modem Heatsink Replacement, Heatsink: 1 단계, 이미지 3개 중 2개 ARRIS Surfboard SB6183 Modem Heatsink Replacement, Heatsink: 1 단계, 이미지 3개 중 3개
    • Use pliers to remove the thin nut and washer from the coax port.
  2. ARRIS Surfboard SB6183 Modem Heatsink Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the single 9mm Torx screw using a Torx T10 screwdriver.
  3. ARRIS Surfboard SB6183 Modem Heatsink Replacement: 3 단계, 이미지 3개 중 1개 ARRIS Surfboard SB6183 Modem Heatsink Replacement: 3 단계, 이미지 3개 중 2개 ARRIS Surfboard SB6183 Modem Heatsink Replacement: 3 단계, 이미지 3개 중 3개
    • Use a spudger to press the plastic retention clip inward and toward the center of the modem.
    • The plastic clip is hidden in a hole beneath the sticker on the bottom of the case.
  4. ARRIS Surfboard SB6183 Modem Heatsink Replacement: 4 단계, 이미지 3개 중 1개 ARRIS Surfboard SB6183 Modem Heatsink Replacement: 4 단계, 이미지 3개 중 2개 ARRIS Surfboard SB6183 Modem Heatsink Replacement: 4 단계, 이미지 3개 중 3개
    • Slide the left side panel of the modem toward the back, then up and out at a shallow angle.
  5. ARRIS Surfboard SB6183 Modem Heatsink Replacement: 5 단계, 이미지 3개 중 1개 ARRIS Surfboard SB6183 Modem Heatsink Replacement: 5 단계, 이미지 3개 중 2개 ARRIS Surfboard SB6183 Modem Heatsink Replacement: 5 단계, 이미지 3개 중 3개
    • There are small plastic tabs on either side of the clear LED diffuser. Use the flat end of a spudger to pry both of them outwards slightly.
  6. ARRIS Surfboard SB6183 Modem Heatsink Replacement: 6 단계, 이미지 2개 중 1개 ARRIS Surfboard SB6183 Modem Heatsink Replacement: 6 단계, 이미지 2개 중 2개
    • Rotate the diffuser upward to unlatch it.
    • You may need to hold the plastic tabs on either side out of the way.
  7. ARRIS Surfboard SB6183 Modem Heatsink Replacement: 7 단계, 이미지 2개 중 1개 ARRIS Surfboard SB6183 Modem Heatsink Replacement: 7 단계, 이미지 2개 중 2개
    • To remove the board, lift the front end up slightly and gently pull toward the front to remove.
    • You may need to wiggle the board loose from the thin clips on either side.
  8. ARRIS Surfboard SB6183 Modem Heatsink Replacement: 8 단계, 이미지 1개 중 1개
    • If your device doesn't have a heatsink, skip this step. To remove an existing heatsink, hold the board steady and use pliers to gently twist it off.
  9. ARRIS Surfboard SB6183 Modem Heatsink Replacement: 9 단계, 이미지 1개 중 1개
    • Peel off the paper backing that protects the thermally conductive adhesive to prepare the heatsink for application.
  10. ARRIS Surfboard SB6183 Modem Heatsink Replacement: 10 단계, 이미지 2개 중 1개 ARRIS Surfboard SB6183 Modem Heatsink Replacement: 10 단계, 이미지 2개 중 2개
    • Center the sticky side of the heatsink over the bare chip, then press down gently to secure it.
    • Make sure the heatsink is stuck in place and will not slide off.
결론
다른 2명이 해당 안내서를 완성하였습니다.
1가이드 댓글
Thank you for this review, helped me to open it. The only thing i did differently is peeled oof the sticker from the bottom - carefully, so not to damage it. Why do u place the heatsink on that specific tiny chip - is it the one that heats up the most? My feeling when opening it was that the RF part was the hottest.
Andru Nl - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 33
전체 시간: 5,827
