주요 콘텐츠로 건너뛰기
ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement
필요한 것
  1. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement, Lower Case: 1 단계, 이미지 1/1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: 2 단계, 이미지 1/1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: 4 단계, 이미지 1/1
    • Use the iFixit opening tool to remove the back of the laptop.
  5. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: 5 단계, 이미지 1/1
    • Use the blunt nose tweezers to separate the keyboard from the internal components.
  6. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement, Audio Ports: 6 단계, 이미지 1/1
    • Remove the four 3mm J1 screws attached to the audio cards.
  7. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: 7 단계, 이미지 1/2 ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: 7 단계, 이미지 2/2
    • Lift and remove the audio cards.
    • Separate the wires from the motherboard.
결론
Tomas Martinez
회원 가입일: 01/24/19
185 평판
안내서 1개 작성함
Cal Poly, Team S19-G4, White Winter 2019 Cal Poly, Team S19-G4, White Winter 2019 회원
CPSU-WHITE-W19S19G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 4
30일 전: 5
전체 시간: 135
