주요 콘텐츠로 건너뛰기
ASUS Chromebook C100PA-RBRKT07 Battery Replacement
필요한 것
  1. ASUS Chromebook C100PA-RBRKT07 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 2 단계, 이미지 1/1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the T5 screwdriver to remove the 6 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 4 단계, 이미지 1/1
    • Use the iFixit opening tool to pry the backing of the device off.
  5. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 5 단계, 이미지 1/1
    • Use the tweezers to separate the cables from the motherboard.
    • You need to reach inside and peel some tape to disconnect the wire.
  6. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 6 단계, 이미지 1/1
    • Use the JIS1 screwdriver to remove the four 2.1 mm screws around the audio cards.
  7. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 7 단계, 이미지 1/2 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 7 단계, 이미지 2/2
    • Gently disconnect the audio cards, exposing the battery.
  8. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 8 단계, 이미지 1/1
    • Use the J00 screwdriver to remove the three 1.7 mm battery screws.
  9. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 9 단계, 이미지 1/3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 9 단계, 이미지 2/3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 9 단계, 이미지 3/3
    • Grip the battery and remove it from the device.
    • Remove the battery cable out of the motherboard by lifting the battery cables.
결론
Tiffany Foo
회원 가입일: 01/24/19
289 평판
안내서 2개 작성하였습니다
Cal Poly, Team S19-G4, White Winter 2019 Cal Poly, Team S19-G4, White Winter 2019 회원
CPSU-WHITE-W19S19G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 15
전체 시간: 380
