주요 콘텐츠로 건너뛰기
ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement
필요한 것
  1. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement, Lower Case: 1 단계, 이미지 1/1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: 2 단계, 이미지 1/1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: 4 단계, 이미지 1/1
    • Use the iFixit opening tool to remove the back of the laptop.
  5. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement: 5 단계, 이미지 1/1
    • Use the blunt nose tweezers to separate the keyboard from the internal components.
  6. ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement, Keyboard: 6 단계, 이미지 1/2 ASUS Chromebook C100PA-RBRKT07 Keyboard Replacement, Keyboard: 6 단계, 이미지 2/2
    • Remove the keyboard from the laptop.
    • The Trackpad is attached to the keyboard assembly. The Trackpad replacement guide can be found on the ASUS Chromebook CPPA-RBRKT07 homepage.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anthony Gomez
회원 가입일: 01/25/19
94 평판
안내서 1개 작성함
Cal Poly, Team S19-G4, White Winter 2019 Cal Poly, Team S19-G4, White Winter 2019 회원
CPSU-WHITE-W19S19G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 458
