주요 콘텐츠로 건너뛰기
ASUS Chromebook C200MA DS01 Battery Replacement
필요한 것
  1. ASUS Chromebook C200MA DS01 Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Battery Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Battery Replacement: 3 단계, 이미지 1/1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Battery Replacement, Battery Connection: 4 단계, 이미지 1/3 ASUS Chromebook C200MA DS01 Battery Replacement, Battery Connection: 4 단계, 이미지 2/3 ASUS Chromebook C200MA DS01 Battery Replacement, Battery Connection: 4 단계, 이미지 3/3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Battery Replacement, Battery: 5 단계, 이미지 1/2 ASUS Chromebook C200MA DS01 Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Battery Replacement: 6 단계, 이미지 1/1
    • Pull out the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Christopher Lim
회원 가입일: 04/26/17
779 평판
안내서 7개 작성하였습니다
Cal Poly, Team S23-G4, Livingston Spring 2017 Cal Poly, Team S23-G4, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S23G4
4 회원들
안내서 19개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 47
전체 시간: 13,406
