주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Chromebook C200MA DS01 Touchpad Replacement
필요한 것
  1. ASUS Chromebook C200MA DS01 Touchpad Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Touchpad Replacement: 2 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Touchpad Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: 4 단계, 이미지 3개 중 1개 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: 4 단계, 이미지 3개 중 2개 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: 4 단계, 이미지 3개 중 3개
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: 5 단계, 이미지 2개 중 1개 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Touchpad Replacement: 6 단계, 이미지 1개 중 1개
    • Pull out the battery.
  7. ASUS Chromebook C200MA DS01 Touchpad Replacement, Touchpad: 7 단계, 이미지 1개 중 1개
    • Locate the touchpad.
    • Locate the touch pad cable connector.
  8. ASUS Chromebook C200MA DS01 Touchpad Replacement: 8 단계, 이미지 3개 중 1개 ASUS Chromebook C200MA DS01 Touchpad Replacement: 8 단계, 이미지 3개 중 2개 ASUS Chromebook C200MA DS01 Touchpad Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect the touch pad ZIF(zero insertion force) connector.
    • Flip the flap up using a spudger or your fingers.
    • Pull gently on the ribbon cable to disconnect.
  9. ASUS Chromebook C200MA DS01 Touchpad Replacement: 9 단계, 이미지 1개 중 1개
    • Gently remove the adhesive on the touch pad ribbon cable.
  10. ASUS Chromebook C200MA DS01 Touchpad Replacement: 10 단계, 이미지 3개 중 1개 ASUS Chromebook C200MA DS01 Touchpad Replacement: 10 단계, 이미지 3개 중 2개 ASUS Chromebook C200MA DS01 Touchpad Replacement: 10 단계, 이미지 3개 중 3개
    • Gently remove the metallic tape from the touch pad only.
    • Try not to tear the tape, it can be re-used during reassembly.
  11. ASUS Chromebook C200MA DS01 Touchpad Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the three 1.8 mm Phillips #00 screws.
  12. ASUS Chromebook C200MA DS01 Touchpad Replacement: 12 단계, 이미지 2개 중 1개 ASUS Chromebook C200MA DS01 Touchpad Replacement: 12 단계, 이미지 2개 중 2개
    • Lift the far edge of the touch pad to remove it.
결론
작성자
2다른 기여자 명과 함께
Christopher Lim
회원 가입일: 04/26/17
779 평판
안내서 7개를 작성함
Cal Poly, Team S23-G4, Livingston Spring 2017 Cal Poly, Team S23-G4, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S23G4
4 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 29
전체 시간: 783
