주요 콘텐츠로 건너뛰기
ASUS Chromebook C300MA-DH01 Audio Speakers Replacement
필요한 것
  1. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement, Audio Speakers: 1 단계, 이미지 1/1
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 2 단계, 이미지 1/2 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 2 단계, 이미지 2/2
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom:
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 3 단계, 이미지 1/3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 3 단계, 이미지 2/3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 3 단계, 이미지 3/3
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 4 단계, 이미지 1/3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 4 단계, 이미지 2/3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 4 단계, 이미지 3/3
    • Gently detach connecting cables
    • Carefully flip up the large black tab.
    • Carefully flip up the small white tab.
    • Remove its corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
  5. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 5 단계, 이미지 1/2 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 5 단계, 이미지 2/2
    • Using the JIS-J0 screwdriver, unscrew and remove from the battery:
    • (6) Six 6mm screws
  6. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 6 단계, 이미지 1/1
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
  7. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 7 단계, 이미지 1/2 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 7 단계, 이미지 2/2
    • Using the plastic opening tool, disconnect the audio connector by pushing the audio tab toward the speakers.
    • With the audio cable detached, carefully lift the speakers out of the device.
결론
Gina Altimari
회원 가입일: 09/28/17
401 평판
안내서 4개 작성하였습니다
USF Tampa, Team S2-G5, Passmore Fall 2017 USF Tampa, Team S2-G5, Passmore Fall 2017 회원
USFT-PASSMORE-F17S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 126
