주요 콘텐츠로 건너뛰기
ASUS Chromebook C300MA-DH01 Display Replacement
필요한 것
  1. ASUS Chromebook C300MA-DH01 Display Replacement, Display: 1 단계, 이미지 1/3 ASUS Chromebook C300MA-DH01 Display Replacement, Display: 1 단계, 이미지 2/3 ASUS Chromebook C300MA-DH01 Display Replacement, Display: 1 단계, 이미지 3/3
    • Flip open the Chromebook as shown. Using the plastic opening tool, gently pry open the hinge cover of the display. Once it snaps off, remove the hinge cover.
  2. ASUS Chromebook C300MA-DH01 Display Replacement: 2 단계, 이미지 1/1
    • Continue to use the plastic spudger to gently pry the front frame from the display. It will come off with a snap.
  3. ASUS Chromebook C300MA-DH01 Display Replacement: 3 단계, 이미지 1/2 ASUS Chromebook C300MA-DH01 Display Replacement: 3 단계, 이미지 2/2
    • Using the JIS J000 Screwdriver, unscrew and remove the (4) four 3mm screws from the display.
  4. ASUS Chromebook C300MA-DH01 Display Replacement: 4 단계, 이미지 1/1
    • Gently peel back the tape to remove the display.
결론
Gina Altimari
회원 가입일: 09/28/17
401 평판
안내서 4개 작성하였습니다
USF Tampa, Team S2-G5, Passmore Fall 2017 USF Tampa, Team S2-G5, Passmore Fall 2017 회원
USFT-PASSMORE-F17S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 167
