주요 콘텐츠로 건너뛰기
ASUS Chromebook C300MA-DH01 Motherboard Replacement
필요한 것
  1. ASUS Chromebook C300MA-DH01 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Motherboard Replacement: 2 단계, 이미지 1/2 ASUS Chromebook C300MA-DH01 Motherboard Replacement: 2 단계, 이미지 2/2
    • Using the JIS J0 Screwdriver, remove the following screws from the bottom:
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Motherboard Replacement: 3 단계, 이미지 1/3 ASUS Chromebook C300MA-DH01 Motherboard Replacement: 3 단계, 이미지 2/3 ASUS Chromebook C300MA-DH01 Motherboard Replacement: 3 단계, 이미지 3/3
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Motherboard Replacement: 4 단계, 이미지 1/3 ASUS Chromebook C300MA-DH01 Motherboard Replacement: 4 단계, 이미지 2/3 ASUS Chromebook C300MA-DH01 Motherboard Replacement: 4 단계, 이미지 3/3
    • Gently detach connecting cables.
    • Carefully flip up the large black tab.
    • Carefully flip up the small white tab.
    • Remove its corresponding black cable.
    • Remove its corresponding white cable.
    • The keyboard will be fully detached at this point. Set it aside for now.
  5. ASUS Chromebook C300MA-DH01 Motherboard Replacement: 5 단계, 이미지 1/1
    • Using the JIS J0 Screwdriver, unscrew and remove the (6) six 6mm screws from the device.
  6. ASUS Chromebook C300MA-DH01 Motherboard Replacement: 6 단계, 이미지 1/1
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
  7. ASUS Chromebook C300MA-DH01 Motherboard Replacement: 7 단계, 이미지 1/1
    • Using the plastic opening tool, disconnect the audio connection by pushing the audio tab toward the speakers.
    • With the audio cable detached, carefully lift the speakers out of the device.
  8. ASUS Chromebook C300MA-DH01 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the LCD cable from the motherboard.
    • Peel back the tape and then gently pull back on the connector cable.
  9. ASUS Chromebook C300MA-DH01 Motherboard Replacement: 9 단계, 이미지 1/1
    • Using the JIS J0 screwdriver, unscrew the 3mm screw.
    • Remove the Wi-Fi card from the motherboard.
  10. ASUS Chromebook C300MA-DH01 Motherboard Replacement: 10 단계, 이미지 1/1
    • Using the plastic opening tool, lift up on data cable for the daughterboard to remove it from the device.
  11. ASUS Chromebook C300MA-DH01 Motherboard Replacement: 11 단계, 이미지 1/2 ASUS Chromebook C300MA-DH01 Motherboard Replacement: 11 단계, 이미지 2/2
    • Using the JIS J0 Screwdriver unscrew and remove the (2) two 3 mm screws from the heat shield.
    • Gently lift up on the heat shield to remove it.
  12. ASUS Chromebook C300MA-DH01 Motherboard Replacement: 12 단계, 이미지 1/1
    • Using the JIS J0 Screwdriver, unscrew and remove the (3) three 6mm screws from the left hinge.
  13. ASUS Chromebook C300MA-DH01 Motherboard Replacement: 13 단계, 이미지 1/2 ASUS Chromebook C300MA-DH01 Motherboard Replacement: 13 단계, 이미지 2/2
    • Using the JIS J0 Screwdriver, unscrew and removing the following:
    • (1) One 3mm screw from the right side of the motherboard.
    • (1) One 4mm silver screw from the left side of the motherboard.
    • The motherboard can now be carefully removed from the device.
결론
Gina Altimari
회원 가입일: 09/28/17
401 평판
안내서 4개 작성하였습니다
USF Tampa, Team S2-G5, Passmore Fall 2017 USF Tampa, Team S2-G5, Passmore Fall 2017 회원
USFT-PASSMORE-F17S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 8
전체 시간: 209
