소개
If you have started noticing that your laptop loses power faster than before, or if it randomly shuts down when high on charge, a faulty battery is likely the cause. This guide will provide the necessary components and steps to remove and replace your E210MA battery.
필요한 것
Place the laptop with the bottom side facing up. Have the front (where the mousepad is) facing toward you.
Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 JIS screwdriver.
거의 끝나갑니다!
결론
