주요 콘텐츠로 건너뛰기
ASUS Eee Pad Transformer Back Facing Camera Replacement
필요한 것
  1. ASUS Eee Pad Transformer Back Facing Camera Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 ASUS Eee Pad Transformer Back Facing Camera Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer Back Facing Camera Replacement: 2 단계, 이미지 3개 중 1개 ASUS Eee Pad Transformer Back Facing Camera Replacement: 2 단계, 이미지 3개 중 2개 ASUS Eee Pad Transformer Back Facing Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Back Facing Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Back Facing Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Back Facing Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Back Facing Camera Replacement: 6 단계, 이미지 2개 중 1개 ASUS Eee Pad Transformer Back Facing Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer Back Facing Camera Replacement, Pull out flap: 7 단계, 이미지 2개 중 1개 ASUS Eee Pad Transformer Back Facing Camera Replacement, Pull out flap: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use Tweezers to pull out gold flap connected to bottom of camera.
    • Pull the gold flap to take out the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sandy Babich
회원 가입일: 09/23/14
1,909 평판
안내서 5개를 작성함
Cal Poly, Team 13-9, Forte Fall 2014 Cal Poly, Team 13-9, Forte Fall 2014 회원
CPSU-FORTE-F14S13G9
5 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 1,255
