주요 콘텐츠로 건너뛰기
ASUS Eee Pad Transformer Charging Port Replacement
필요한 것
  1. ASUS Eee Pad Transformer Charging Port Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 ASUS Eee Pad Transformer Charging Port Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer Charging Port Replacement: 2 단계, 이미지 3개 중 1개 ASUS Eee Pad Transformer Charging Port Replacement: 2 단계, 이미지 3개 중 2개 ASUS Eee Pad Transformer Charging Port Replacement: 2 단계, 이미지 3개 중 3개
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Charging Port Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Charging Port Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Charging Port Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Charging Port Replacement: 6 단계, 이미지 2개 중 1개 ASUS Eee Pad Transformer Charging Port Replacement: 6 단계, 이미지 2개 중 2개
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer Charging Port Replacement, Remove screws: 7 단계, 이미지 1개 중 1개
    • Use a Phillips #00 Screwdriver to remove the two 3 millimeter screws found at the bottom center of the tablet near the charging port.
  8. ASUS Eee Pad Transformer Charging Port Replacement, Lift up white flap: 8 단계, 이미지 1개 중 1개
    • Use Plastic Opening Tool to lift up the white flap found to the left of the charging port.
  9. ASUS Eee Pad Transformer Charging Port Replacement: 9 단계, 이미지 1개 중 1개
    • Use Plastic Opening Tool to lift up the charging port.
  10. ASUS Eee Pad Transformer Charging Port Replacement, Pull out panel: 10 단계, 이미지 2개 중 1개 ASUS Eee Pad Transformer Charging Port Replacement, Pull out panel: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use Tweezers to wiggle the port panel out from underneath the metal bar.
    • Make sure red tab does not get caught underneath the metal bar when pulling out the port component, otherwise it will damage the charging port panel.
결론
다른 15명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sandy Babich
회원 가입일: 09/23/14
1,909 평판
안내서 5개를 작성함
Cal Poly, Team 13-9, Forte Fall 2014 Cal Poly, Team 13-9, Forte Fall 2014 회원
CPSU-FORTE-F14S13G9
5 회원들
안내서 12개를 작성함
댓글 2개
Thanks for this guide. I managed to change the port and that fixed my Transformer. I had some difficulty(my fingers are not nimble) so I had to cut away the metal bar to get the panel beneath the white flap.
villepaakkinen - 답글
So my tablet will not hold a charge, but will work on the charger. I also have the separate keyboard/docking station and it will not hold a charge. Does this mean both of my tablet and my docking station need a new charge port or does the table charge the docking station and it is just bad. Both come on when physically plugged into the usb charger.
caramarie - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 25
전체 시간: 23,103
