주요 콘텐츠로 건너뛰기
ASUS F555UA-EH71 Battery Replacement
필요한 것
  1. ASUS F555UA-EH71 Battery Replacement, Keyboard Panel: 1 단계, 이미지 1/1
    • Remove the ten 18 mm screws holding down the outer shell of the laptop using the Phillips #000 screwdriver.
  2. ASUS F555UA-EH71 Battery Replacement: 2 단계, 이미지 1/2 ASUS F555UA-EH71 Battery Replacement: 2 단계, 이미지 2/2
    • Use your fingers to gently pry open the gap between the silver and black parts of the casing.
    • Separate the keyboard panel from the body of the laptop by wedging the iFixit Opening Tool in between the keyboard panel and the body.
    • The teeth of the casing should make a clicking noise as they’re pulled apart.
  3. ASUS F555UA-EH71 Battery Replacement: 3 단계, 이미지 1/1
    • Gently open the casing until the white, silver, and gold power strips are visible. Gently peel the strips from the bottom side of the laptop.
    • Disconnect the two cables connecting the keyboard panel to the laptop.
  4. ASUS F555UA-EH71 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the keyboard panel from the laptop.
  5. ASUS F555UA-EH71 Battery Replacement, Battery: 5 단계, 이미지 1/3 ASUS F555UA-EH71 Battery Replacement, Battery: 5 단계, 이미지 2/3 ASUS F555UA-EH71 Battery Replacement, Battery: 5 단계, 이미지 3/3
    • Use the Phillips #000 screwdriver to remove the eight 4 mm screws holding the battery in place.
  6. ASUS F555UA-EH71 Battery Replacement: 6 단계, 이미지 1/2 ASUS F555UA-EH71 Battery Replacement: 6 단계, 이미지 2/2
    • Carefully remove the battery from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jared Curtis
회원 가입일: 09/16/19
263 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 17
전체 시간: 947
