주요 콘텐츠로 건너뛰기
ASUS K200MA-DS01T Back Panel Removal
필요한 것
  1. ASUS K200MA-DS01T Back Panel Removal, Back Panel: 1 단계, 이미지 1/2 ASUS K200MA-DS01T Back Panel Removal, Back Panel: 1 단계, 이미지 2/2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Back Panel Removal: 2 단계, 이미지 1/2 ASUS K200MA-DS01T Back Panel Removal: 2 단계, 이미지 2/2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Back Panel Removal: 3 단계, 이미지 1/1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Back Panel Removal: 4 단계, 이미지 1/3 ASUS K200MA-DS01T Back Panel Removal: 4 단계, 이미지 2/3 ASUS K200MA-DS01T Back Panel Removal: 4 단계, 이미지 3/3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
결론
Haleigh St. Paul
회원 가입일: 09/17/18
239 평판
안내서 1개 작성함
CSU Fullerton, Team S2-G5, Bruce Fall 2018 CSU Fullerton, Team S2-G5, Bruce Fall 2018 회원
CSUF-BRUCE-F18S2G5
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 9
전체 시간: 192
