주요 콘텐츠로 건너뛰기
ASUS K200MA-DS01T Battery Replacement
필요한 것
  1. ASUS K200MA-DS01T Battery Replacement, Back Panel: 1 단계, 이미지 1/2 ASUS K200MA-DS01T Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Battery Replacement: 2 단계, 이미지 1/2 ASUS K200MA-DS01T Battery Replacement: 2 단계, 이미지 2/2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Battery Replacement: 3 단계, 이미지 1/1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Battery Replacement: 4 단계, 이미지 1/3 ASUS K200MA-DS01T Battery Replacement: 4 단계, 이미지 2/3 ASUS K200MA-DS01T Battery Replacement: 4 단계, 이미지 3/3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Battery Replacement, Keyboard: 5 단계, 이미지 1/2 ASUS K200MA-DS01T Battery Replacement, Keyboard: 5 단계, 이미지 2/2
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Battery Replacement: 6 단계, 이미지 1/2 ASUS K200MA-DS01T Battery Replacement: 6 단계, 이미지 2/2
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. ASUS K200MA-DS01T Battery Replacement, Battery: 7 단계, 이미지 1/2 ASUS K200MA-DS01T Battery Replacement, Battery: 7 단계, 이미지 2/2
    • Flip the computer over so that the side with the motherboard (large green piece) is laying face-up.
    • Remove the following screws from the middle and far ends of the battery:
    • Three 4mm Phillips screws using a Phillips #0 screwdriver.
    • The battery will be located closest to the screen.
  8. ASUS K200MA-DS01T Battery Replacement: 8 단계, 이미지 1/3 ASUS K200MA-DS01T Battery Replacement: 8 단계, 이미지 2/3 ASUS K200MA-DS01T Battery Replacement: 8 단계, 이미지 3/3
    • Gripping the wider left section, lift the battery up and away from computer.
결론
Aliyah Malapit
회원 가입일: 09/26/18
199 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team S2-G5, Bruce Fall 2018 CSU Fullerton, Team S2-G5, Bruce Fall 2018 회원
CSUF-BRUCE-F18S2G5
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 301
