주요 콘텐츠로 건너뛰기
ASUS K200MA-DS01T Trackpad Replacement
필요한 것
  1. ASUS K200MA-DS01T Trackpad Replacement, Back Panel: 1 단계, 이미지 1/2 ASUS K200MA-DS01T Trackpad Replacement, Back Panel: 1 단계, 이미지 2/2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Trackpad Replacement: 2 단계, 이미지 1/2 ASUS K200MA-DS01T Trackpad Replacement: 2 단계, 이미지 2/2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Trackpad Replacement: 3 단계, 이미지 1/1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Trackpad Replacement: 4 단계, 이미지 1/3 ASUS K200MA-DS01T Trackpad Replacement: 4 단계, 이미지 2/3 ASUS K200MA-DS01T Trackpad Replacement: 4 단계, 이미지 3/3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Trackpad Replacement, Keyboard: 5 단계, 이미지 1/2 ASUS K200MA-DS01T Trackpad Replacement, Keyboard: 5 단계, 이미지 2/2
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Trackpad Replacement: 6 단계, 이미지 1/2 ASUS K200MA-DS01T Trackpad Replacement: 6 단계, 이미지 2/2
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. ASUS K200MA-DS01T Trackpad Replacement, Track Pad: 7 단계, 이미지 1/2 ASUS K200MA-DS01T Trackpad Replacement, Track Pad: 7 단계, 이미지 2/2
    • Lift the keyboard connector from the keyboard.
  8. ASUS K200MA-DS01T Trackpad Replacement: 8 단계, 이미지 1/2 ASUS K200MA-DS01T Trackpad Replacement: 8 단계, 이미지 2/2
    • Lift the foil sheet.
  9. ASUS K200MA-DS01T Trackpad Replacement: 9 단계, 이미지 1/2 ASUS K200MA-DS01T Trackpad Replacement: 9 단계, 이미지 2/2
    • Eight 3 mm screws using Phillips screwdriver.
    • Be sure to remove the screw underneath the keyboard connector.
  10. ASUS K200MA-DS01T Trackpad Replacement: 10 단계, 이미지 1/1
    • Two 2 mm screws using a Phillips #00 screwdriver.
  11. ASUS K200MA-DS01T Trackpad Replacement: 11 단계, 이미지 1/2 ASUS K200MA-DS01T Trackpad Replacement: 11 단계, 이미지 2/2
    • Using a plastic spudger, remove the metal plate.
  12. ASUS K200MA-DS01T Trackpad Replacement: 12 단계, 이미지 1/3 ASUS K200MA-DS01T Trackpad Replacement: 12 단계, 이미지 2/3 ASUS K200MA-DS01T Trackpad Replacement: 12 단계, 이미지 3/3
    • Flip the keyboard over.
    • Using a plastic spudger, pry the track pad off the plastic piece underneath.
    • Don't be afraid to use some force in this step because the track pad and the plastic piece are glued together.
결론
Terrinda
회원 가입일: 09/17/18
526 평판
안내서 4개 작성하였습니다
CSU Fullerton, Team S2-G5, Bruce Fall 2018 CSU Fullerton, Team S2-G5, Bruce Fall 2018 회원
CSUF-BRUCE-F18S2G5
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 99
