주요 콘텐츠로 건너뛰기
ASUS K43SV SSD Replacement
필요한 것
  1. ASUS K43SV SSD Replacement, SSD: 1 단계, 이미지 1/1
    • Disconnect the ASUS k43sv laptop from the external power supply before starting.
    • Place the laptop on a flat table with its back facing up.
  2. ASUS K43SV SSD Replacement: 2 단계, 이미지 1/1
    • Slide the latch on the right side of the battery on the back of the laptop to the right to the unlocked position.
  3. ASUS K43SV SSD Replacement: 3 단계, 이미지 1/3 ASUS K43SV SSD Replacement: 3 단계, 이미지 2/3 ASUS K43SV SSD Replacement: 3 단계, 이미지 3/3
    • With your left hand, slide the latch on the left side of the battery to the left and hold it.
    • With your right hand, slide the battery out of the battery compartment and place the battery away from the laptop.
  4. ASUS K43SV SSD Replacement: 4 단계, 이미지 1/2 ASUS K43SV SSD Replacement: 4 단계, 이미지 2/2
    • Remove the two screws on the bottom of the laptop using a Phillips #0 screwdriver.
  5. ASUS K43SV SSD Replacement: 5 단계, 이미지 1/3 ASUS K43SV SSD Replacement: 5 단계, 이미지 2/3 ASUS K43SV SSD Replacement: 5 단계, 이미지 3/3
    • Slide the hard disk compartment cover towards you with both hands and remove it from the laptop.
  6. ASUS K43SV SSD Replacement: 6 단계, 이미지 1/3 ASUS K43SV SSD Replacement: 6 단계, 이미지 2/3 ASUS K43SV SSD Replacement: 6 단계, 이미지 3/3
    • Remove the four screws from the hard drive support arm using a Phillips #0 screwdriver.
  7. ASUS K43SV SSD Replacement: 7 단계, 이미지 1/3 ASUS K43SV SSD Replacement: 7 단계, 이미지 2/3 ASUS K43SV SSD Replacement: 7 단계, 이미지 3/3
    • Lift the plastic sheet on the left side of the hard drive slightly by hand.
    • Remove the hard drive and its support from the hard drive compartment.
  8. ASUS K43SV SSD Replacement: 8 단계, 이미지 1/3 ASUS K43SV SSD Replacement: 8 단계, 이미지 2/3 ASUS K43SV SSD Replacement: 8 단계, 이미지 3/3
    • Remove the four screws on the side of the hard disk support using a Phillips #0 screwdriver.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Duanrui Liu
회원 가입일: 09/20/21
279 평판
안내서 1개 작성함
York University, Team S-14, Woodhouse Winter 2022 York University, Team S-14, Woodhouse Winter 2022 회원
YORK-WOODHOUSE-W22SSG14
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 48
전체 시간: 934
