주요 콘텐츠로 건너뛰기
ASUS K53E-BBR1 Hard Drive Replacement
필요한 것
  1. ASUS K53E-BBR1 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over so you can see the battery.
  2. ASUS K53E-BBR1 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
  3. ASUS K53E-BBR1 Hard Drive Replacement: 3 단계, 이미지 1/3 ASUS K53E-BBR1 Hard Drive Replacement: 3 단계, 이미지 2/3 ASUS K53E-BBR1 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
  4. ASUS K53E-BBR1 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/2 ASUS K53E-BBR1 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Remove the two 4mm Phillips #0 screws on either side of the laptop.
  5. ASUS K53E-BBR1 Hard Drive Replacement: 5 단계, 이미지 1/2 ASUS K53E-BBR1 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Slide the back panel towards you until it stops.
    • Lift the panel up out of the laptop casing.
  6. ASUS K53E-BBR1 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Remove the four 3mm Phillips #0 screws holding the hard drive in place.
  7. ASUS K53E-BBR1 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Disconnect the hard drive from the laptop by sliding it towards the outside edge.
  8. ASUS K53E-BBR1 Hard Drive Replacement: 8 단계, 이미지 1/2 ASUS K53E-BBR1 Hard Drive Replacement: 8 단계, 이미지 2/2
    • Grab hold of the black cloth tab and pull the hard drive out from the laptop.
결론
Matthew Merlo
회원 가입일: 03/20/19
267 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S6-G4, Peak Spring 2019 UMass Dartmouth, Team S6-G4, Peak Spring 2019 회원
UMASSD-PEAK-S19S6G4
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 267
