주요 콘텐츠로 건너뛰기
ASUS K53E-BBR1 RAM Replacement
필요한 것
  1. ASUS K53E-BBR1 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over so you can see the battery.
  2. ASUS K53E-BBR1 RAM Replacement: 2 단계, 이미지 1/1
    • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
  3. ASUS K53E-BBR1 RAM Replacement: 3 단계, 이미지 1/3 ASUS K53E-BBR1 RAM Replacement: 3 단계, 이미지 2/3 ASUS K53E-BBR1 RAM Replacement: 3 단계, 이미지 3/3
    • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
  4. ASUS K53E-BBR1 RAM Replacement, RAM: 4 단계, 이미지 1/2 ASUS K53E-BBR1 RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Remove the two 4mm Phillips #0 screws located on the opposite ends of the laptop.
  5. ASUS K53E-BBR1 RAM Replacement: 5 단계, 이미지 1/2 ASUS K53E-BBR1 RAM Replacement: 5 단계, 이미지 2/2
    • Slide the back panel backwards until it stops.
    • You can now lift the panel up and out of the laptop casing.
  6. ASUS K53E-BBR1 RAM Replacement: 6 단계, 이미지 1/3 ASUS K53E-BBR1 RAM Replacement: 6 단계, 이미지 2/3 ASUS K53E-BBR1 RAM Replacement: 6 단계, 이미지 3/3
    • The RAM is now visible.
    • Remove the RAM by pressing out on both tabs visible on each side of the RAM.
    • To work the tabs, take your finger tips and press outwards from the indents on the RAM.
  7. ASUS K53E-BBR1 RAM Replacement: 7 단계, 이미지 1/2 ASUS K53E-BBR1 RAM Replacement: 7 단계, 이미지 2/2
    • The RAM is now angled up and you can remove the RAM by pulling it out in the direction it is facing.
    • Gently Pull the RAM out of its connector without pushing down or pulling up.
  8. ASUS K53E-BBR1 RAM Replacement: 8 단계, 이미지 1/3 ASUS K53E-BBR1 RAM Replacement: 8 단계, 이미지 2/3 ASUS K53E-BBR1 RAM Replacement: 8 단계, 이미지 3/3
    • Repeat the previous two steps for the second stick of RAM.
결론
William Colangelo
회원 가입일: 03/25/19
121 평판
안내서 1개 작성함
UMass Dartmouth, Team S6-G4, Peak Spring 2019 UMass Dartmouth, Team S6-G4, Peak Spring 2019 회원
UMASSD-PEAK-S19S6G4
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 10
전체 시간: 209
