주요 콘텐츠로 건너뛰기
ASUS K553MA-DB01TQ Battery Replacement
필요한 것
  1. ASUS K553MA-DB01TQ Battery Replacement, Keyboard: 1 단계, 이미지 1/1
    • Turn the laptop over. Using the Phillips Head 000 bit, remove the four 4.8mm screws from the bottom edge. Use the same bit to then remove the remaining six 9.5mm screws.
  2. ASUS K553MA-DB01TQ Battery Replacement: 2 단계, 이미지 1/1
    • Using the iFixit Opening Tool, pry the keyboard off.
  3. ASUS K553MA-DB01TQ Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the keyboard from the laptop.
    • Be careful of any ribbon cables attached to the keyboard so you don't rip those out.
  4. ASUS K553MA-DB01TQ Battery Replacement: 4 단계, 이미지 1/1
    • Using the Phillips #000, remove the four 9.5mm screws around the battery.
  5. ASUS K553MA-DB01TQ Battery Replacement: 5 단계, 이미지 1/1
    • Carefully disconnect the battery's 8-pin connection to the motherboard.
  6. ASUS K553MA-DB01TQ Battery Replacement: 6 단계, 이미지 1/1
    • Remove the battery from the laptop.
결론
John Wengierski
회원 가입일: 09/06/19
159 평판
안내서 1개 작성함
University of Alabama, Team S1-G4, Bedsole Fall 2019 University of Alabama, Team S1-G4, Bedsole Fall 2019 회원
UA-BEDSOLE-F19S1G4
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 228
