주요 콘텐츠로 건너뛰기
ASUS MeMo Pad FHD10 Battery Replacement
필요한 것
  1. ASUS MeMo Pad FHD10 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure that the device is turned off as a precaution.
    • Unplug the charger and remove any memory card you may have in the device.
    • Wedge the plastic opening tool between the front and back cover on every side.
    • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
    • Once disconnected, remove the back cover from the device screen.
  2. ASUS MeMo Pad FHD10 Battery Replacement: 2 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Battery Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the protective copper sticker and all tape fixed on the device.
    • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
    • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
  3. ASUS MeMo Pad FHD10 Battery Replacement: 3 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
  4. ASUS MeMo Pad FHD10 Battery Replacement: 4 단계, 이미지 3개 중 1개 ASUS MeMo Pad FHD10 Battery Replacement: 4 단계, 이미지 3개 중 2개 ASUS MeMo Pad FHD10 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
    • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
    • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Dmitry
회원 가입일: 01/21/15
391 평판
안내서 3개를 작성함
USF Tampa, Team 9-5, Blackwell Winter 2015 USF Tampa, Team 9-5, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G5
4 회원들
안내서 10개를 작성함
댓글 한 개
Where i can get new battery for this tablet?
Night Knight - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 29
전체 시간: 9,938
