주요 콘텐츠로 건너뛰기
ASUS N550JK-DS71T Laptop Hard Drive Replacement
필요한 것
  1. ASUS N550JK-DS71T Laptop Hard Drive Replacement, Back Case: 1 단계, 이미지 1/2 ASUS N550JK-DS71T Laptop Hard Drive Replacement, Back Case: 1 단계, 이미지 2/2
    • Turn the laptop off and unplug all cables.
    • Flip over so the bottom is facing you.
    • Remove the ten 3mm Torx T5 screws from the bottom cover.
  2. ASUS N550JK-DS71T Laptop Hard Drive Replacement: 2 단계, 이미지 1/2 ASUS N550JK-DS71T Laptop Hard Drive Replacement: 2 단계, 이미지 2/2
    • Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
    • Run the spudger along the perimeter of the bottom cover to remove.
  3. ASUS N550JK-DS71T Laptop Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/2 ASUS N550JK-DS71T Laptop Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/2
    • Remove two 4mm black Phillips #1 screws from CD/DVD bracket.
    • Remove the single 4mm silver Phillips #1 screw from the bottom of the CD/DVD bracket.
    • Remove the CD/DVD bracket.
  4. ASUS N550JK-DS71T Laptop Hard Drive Replacement: 4 단계, 이미지 1/1
    • Remove the four 4mm silver Phillips #1 screws that are holding the hard drive in place.
  5. ASUS N550JK-DS71T Laptop Hard Drive Replacement: 5 단계, 이미지 1/2 ASUS N550JK-DS71T Laptop Hard Drive Replacement: 5 단계, 이미지 2/2
    • Lift up and remove the hard drive from the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Steven Hahn
회원 가입일: 01/29/18
884 평판
안내서 6개 작성하였습니다
USF Tampa, Team S5-G1, Passmore Spring 2018 USF Tampa, Team S5-G1, Passmore Spring 2018 회원
USFT-PASSMORE-S18S5G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 25
전체 시간: 2,555
