주요 콘텐츠로 건너뛰기
ASUS N56JN Laptop Hard Drive Replacement
필요한 것
  1. ASUS N56JN Laptop Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/3 ASUS N56JN Laptop Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/3 ASUS N56JN Laptop Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3/3
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • To prevent data loss, make sure the laptop has fully shut down before removing the battery.
    • Pull the switch on the back of laptop in the direction of the arrow.
    • If done correctly the battery should pop out. Lift the battery to remove it.
  2. ASUS N56JN Laptop Hard Drive Replacement: 2 단계, 이미지 1/2 ASUS N56JN Laptop Hard Drive Replacement: 2 단계, 이미지 2/2
    • Use the screwdriver to remove the rubber cap on the top of the backplate.
  3. ASUS N56JN Laptop Hard Drive Replacement: 3 단계, 이미지 1/3 ASUS N56JN Laptop Hard Drive Replacement: 3 단계, 이미지 2/3 ASUS N56JN Laptop Hard Drive Replacement: 3 단계, 이미지 3/3
    • Remove the screw that was uncovered.
    • Pull the backing plate away from the laptop.
    • This will take a fair amount of force.
  4. ASUS N56JN Laptop Hard Drive Replacement: 4 단계, 이미지 1/3 ASUS N56JN Laptop Hard Drive Replacement: 4 단계, 이미지 2/3 ASUS N56JN Laptop Hard Drive Replacement: 4 단계, 이미지 3/3
    • Remove the four screws located in the corners of the metal bracket.
    • Three of the four screws are the same size. The exception is the bottom left screw, which is significantly shorter. Make sure to put the short screw where it belongs when re-assembling.
  5. ASUS N56JN Laptop Hard Drive Replacement: 5 단계, 이미지 1/3 ASUS N56JN Laptop Hard Drive Replacement: 5 단계, 이미지 2/3 ASUS N56JN Laptop Hard Drive Replacement: 5 단계, 이미지 3/3
    • Push the hard drive away from the center until fully disconnected.
    • Lift the hard drive from the bottom right tab to remove it from the laptop.
  6. ASUS N56JN Laptop Hard Drive Replacement: 6 단계, 이미지 1/3 ASUS N56JN Laptop Hard Drive Replacement: 6 단계, 이미지 2/3 ASUS N56JN Laptop Hard Drive Replacement: 6 단계, 이미지 3/3
    • Remove the four screws on the side of the hard drive and bracket.
  7. ASUS N56JN Laptop Hard Drive Replacement: 7 단계, 이미지 1/2 ASUS N56JN Laptop Hard Drive Replacement: 7 단계, 이미지 2/2
    • Remove the hard drive from the bracket.
  8. ASUS N56JN Laptop Hard Drive Replacement: 8 단계, 이미지 1/2 ASUS N56JN Laptop Hard Drive Replacement: 8 단계, 이미지 2/2
    • Insert the new hard drive into the bracket.
결론
To reassemble your device, follow instructions 1-6 in the reverse order.
다른 8명이 해당 안내서를 완성하였습니다.
Sebastian Jordan
회원 가입일: 10/11/15
308 평판
안내서 1개 작성함
Cal Poly, Team 14-6, Green Fall 2015 Cal Poly, Team 14-6, Green Fall 2015 회원
CPSU-GREEN-F15S14G6
5 회원들
안내서 6개 작성하였습니다
댓글 2개
That’s not rocket science - How to clone the disk properly? that’s the part I can’t manage… Any freeware clone software that actually WORKS and is not just a dumb backup software…?
Günther Haschberger - 답글
The free version of Minitool Partition Wizard is very good.
Edward Falk -
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 25
전체 시간: 14,093
