소개
Replace the battery from your PadFone X.
필요한 것
Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
Work your way around the phone until the entire back cover is loose.
Remove the 13 - 3.6 mm screws using the Torx T5 bit in the screwdriver.
Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
Work your way around the phone until the entire back cover is loose and remove the mid-frame.
Using the blue plastic opening tool, gently disconnect the battery cable from the motherboard.
Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
다른 4명이 해당 안내서를 완성하였습니다.
