주요 콘텐츠로 건너뛰기
ASUS PadFone X Power and Volume Buttons Replacement
필요한 것
  1. ASUS PadFone X Power and Volume Buttons Replacement, Power and Volume Buttons: 1 단계, 이미지 1/1
    • Pry off the back cover with the blue plastic opening tool.
    • Removing the cover may require a bit of force.
  2. ASUS PadFone X Power and Volume Buttons Replacement: 2 단계, 이미지 1/1
    • Remove thirteen 3.6mm screws using the T5 Torx Screwdriver.
  3. ASUS PadFone X Power and Volume Buttons Replacement: 3 단계, 이미지 1/1
    • Once the screws are removed, the mid-frame can be lifted off of the phone.
  4. ASUS PadFone X Power and Volume Buttons Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Grasp the button strip with tweezers.
    • Pull the buttons upwards gently. The buttons should remove easily.
  5. ASUS PadFone X Power and Volume Buttons Replacement: 5 단계, 이미지 1/1
    • Use the blue plastic opening tool to disconnect the orange sensor strip.
    • Applying too much force may damage the connector.
  6. ASUS PadFone X Power and Volume Buttons Replacement: 6 단계, 이미지 1/1
    • Grasp the sensor with the tweezers.
    • Pull outwards away from the phone.
    • The sensor is held on by adhesive. You will need to apply some force when removing.
결론
Madeline Dement
회원 가입일: 01/24/17
114 평판
안내서 1개 작성함
IUPUI, Team 2-1, Baechle Spring 2017 IUPUI, Team 2-1, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S2G1
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 9
전체 시간: 265
