주요 콘텐츠로 건너뛰기
ASUS PadFone X Rear Case Replacement
필요한 것
  1. ASUS PadFone X Rear Case Replacement, Remove the back panel.: 1 단계, 이미지 1/2 ASUS PadFone X Rear Case Replacement, Remove the back panel.: 1 단계, 이미지 2/2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Rear Case Replacement, Antenna replacement: 2 단계, 이미지 1/1
    • Replace the back cover with the new one; the antenna is integrated with the back panel.
결론
John Kue
회원 가입일: 10/07/14
379 평판
안내서 2개 작성하였습니다
USF Tampa, Team 8-4, Leahy Fall 2014 USF Tampa, Team 8-4, Leahy Fall 2014 회원
USFT-LEAHY-F14S8G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 978
