주요 콘텐츠로 건너뛰기
ASUS PadFone X Rear Facing Camera Replacement
필요한 것
  1. ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: 1 단계, 이미지 1/2 ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: 1 단계, 이미지 2/2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upward.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: 2 단계, 이미지 1/3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: 2 단계, 이미지 2/3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: 2 단계, 이미지 3/3
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: 3 단계, 이미지 1/2 ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: 3 단계, 이미지 2/2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera connector.: 4 단계, 이미지 1/1
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera.: 5 단계, 이미지 1/1
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  6. ASUS PadFone X Rear Facing Camera Replacement, Replacing the camera.: 6 단계, 이미지 1/1
    • Once the camera has been pulled out, replace the old camera with a new camera.
결론
nestor
회원 가입일: 10/07/14
101 평판
안내서 1개 작성함
USF Tampa, Team 8-4, Leahy Fall 2014 USF Tampa, Team 8-4, Leahy Fall 2014 회원
USFT-LEAHY-F14S8G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 519
