필요한 것
Using the plastic opening tools, insert it into the edge and pry open.
Use hands to help pull the back off from the front if needed.
Locate (+) and (-) battery terminals
Trace black, white, red, and yellow wires to connection on motherboard
Remove protective plastic cover with tweezers
Gently pry battery off glued surface
Use of a plastic opening tools and a spudger are necessary
다른 5명이 해당 안내서를 완성하였습니다.
댓글 3개
where can i find a battery for that station pls?
Hello dear. Thanks for the tutorial on how to change the Padfone X tablet battery.
I have the Padfone x station without the cell phone because unfortunately my students have stolen it from me in the classroom while attending a mother (in Cordoba, Argentina).
I would like to know, then, if I could adapt an Asus cell phone model by changing the slot in the cell phone and / or in the tablet station in the back where both devices are embedded, so, what kind of spare parts should buy, and with which name to ask.
Since a thousand and one thanks. Best regards from Cordoba, Argentina.
Clara.
