주요 콘텐츠로 건너뛰기
ASUS PadFone X Station Battery Replacement
필요한 것
  1. ASUS PadFone X Station Battery Replacement, Back Cover: 1 단계, 이미지 1/2 ASUS PadFone X Station Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Battery Replacement, Finding the Battery: 2 단계, 이미지 1/1
    • Locate 4600mAh Battery
  3. ASUS PadFone X Station Battery Replacement, Removing the Protective Cover: 3 단계, 이미지 1/2 ASUS PadFone X Station Battery Replacement, Removing the Protective Cover: 3 단계, 이미지 2/2
    • Locate (+) and (-) battery terminals
    • Trace black, white, red, and yellow wires to connection on motherboard
    • Remove protective plastic cover with tweezers
  4. ASUS PadFone X Station Battery Replacement, Disconnecting the Ribbon: 4 단계, 이미지 1/1
    • Disconnect connect ribbon by gently pulling with fingers
    • Ensure the ribbon does not touch metallic items (This may short out battery and cause an explosion)
  5. ASUS PadFone X Station Battery Replacement, Removing the Screws: 5 단계, 이미지 1/2 ASUS PadFone X Station Battery Replacement, Removing the Screws: 5 단계, 이미지 2/2
    • Remove (4) screws
  6. ASUS PadFone X Station Battery Replacement, Taking out the Battery: 6 단계, 이미지 1/3 ASUS PadFone X Station Battery Replacement, Taking out the Battery: 6 단계, 이미지 2/3 ASUS PadFone X Station Battery Replacement, Taking out the Battery: 6 단계, 이미지 3/3
    • Gently pry battery off glued surface
    • Use of a plastic opening tools and a spudger are necessary
결론
다른 5명이 해당 안내서를 완성하였습니다.
Paul Wagner
회원 가입일: 10/07/14
545 평판
안내서 2개 작성하였습니다
USF Tampa, Team 7-4, Leahy Fall 2014 USF Tampa, Team 7-4, Leahy Fall 2014 회원
USFT-LEAHY-F14S7G4
4 회원들
안내서 8개 작성하였습니다
댓글 3개
where can i find a battery for that station pls?
francidorio - 답글
Hello dear. Thanks for the tutorial on how to change the Padfone X tablet battery.
I have the Padfone x station without the cell phone because unfortunately my students have stolen it from me in the classroom while attending a mother (in Cordoba, Argentina).
I would like to know, then, if I could adapt an Asus cell phone model by changing the slot in the cell phone and / or in the tablet station in the back where both devices are embedded, so, what kind of spare parts should buy, and with which name to ask.
Since a thousand and one thanks. Best regards from Cordoba, Argentina.
Clara.
calejanmm - 답글
The proper battery for this unit is C11P1323.
acg - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 3,641
