주요 콘텐츠로 건너뛰기
ASUS PadFone X Station Docking Connector Replacement
필요한 것
  1. ASUS PadFone X Station Docking Connector Replacement, Back Cover: 1 단계, 이미지 1/2 ASUS PadFone X Station Docking Connector Replacement, Back Cover: 1 단계, 이미지 2/2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Docking Connector Replacement, USB connector: 2 단계, 이미지 1/2 ASUS PadFone X Station Docking Connector Replacement, USB connector: 2 단계, 이미지 2/2
    • Locate the CON101
    • The white sticker indicates water exposure. White=none, Red=Exposure
  3. ASUS PadFone X Station Docking Connector Replacement, Remove two Phillips screws: 3 단계, 이미지 1/1
    • Remove two Phillips screws
  4. ASUS PadFone X Station Docking Connector Replacement, Locate P92L on CON1504: 4 단계, 이미지 1/2 ASUS PadFone X Station Docking Connector Replacement, Locate P92L on CON1504: 4 단계, 이미지 2/2
    • Locate P92L on CON1504
    • Gently peel back and remove plastic tape
  5. ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: 5 단계, 이미지 1/3 ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: 5 단계, 이미지 2/3 ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: 5 단계, 이미지 3/3
    • Gently Pull P92L With Fingers From CON1504
  6. ASUS PadFone X Station Docking Connector Replacement, Identification of Antenna Wires: 6 단계, 이미지 1/1
    • These are the antenna wires.
    • Trace these wires to locate the two antennas.
  7. ASUS PadFone X Station Docking Connector Replacement, Desolder the two antenna wires: 7 단계, 이미지 1/2 ASUS PadFone X Station Docking Connector Replacement, Desolder the two antenna wires: 7 단계, 이미지 2/2
    • Locate the two antennas
    • Desolder the two antenna wires
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel
회원 가입일: 10/07/14
338 평판
안내서 2개 작성하였습니다
USF Tampa, Team 7-4, Leahy Fall 2014 USF Tampa, Team 7-4, Leahy Fall 2014 회원
USFT-LEAHY-F14S7G4
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 1,426
