주요 콘텐츠로 건너뛰기
ASUS PadFone X Station Power and Volume Contacts Replacement
필요한 것
  1. ASUS PadFone X Station Power and Volume Contacts Replacement, Back Cover: 1 단계, 이미지 1/2 ASUS PadFone X Station Power and Volume Contacts Replacement, Back Cover: 1 단계, 이미지 2/2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Power and Volume Contacts Replacement, Locate CON1501: 2 단계, 이미지 1/1
    • Locate CON1501
    • CON1501 will be visible underneath the contacts. You can readily see this if you look for the orange strip of film in the top right corner of the back of the Asus Padfone X Docking Station.
  3. ASUS PadFone X Station Power and Volume Contacts Replacement, Remove (1) phillips screw.: 3 단계, 이미지 1/1
    • Remove (1) phillips screw
    • Using a +PH00 Phillips screwdriver , you will unscrew the Phillips screw in the top right corner of the back of the ASUS Padfone X docking station.
    • To unscrew the Phillips screw simply position the screwdriver inside of the screw, then rotate it counter-clockwise until the screw is fully removed from the docking station.
  4. ASUS PadFone X Station Power and Volume Contacts Replacement, Disconnect ribbon from CON1510: 4 단계, 이미지 1/2 ASUS PadFone X Station Power and Volume Contacts Replacement, Disconnect ribbon from CON1510: 4 단계, 이미지 2/2
    • Disconnect ribbon from CON1510
    • To disconnect the ribbon from CON1510, use a pair of tweezers and gently lift the connect up and back from the device.
  5. ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: 5 단계, 이미지 1/3 ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: 5 단계, 이미지 2/3 ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: 5 단계, 이미지 3/3
    • Now that the contacts are no longer attached, you can use either tweezers or your fingers to grasp and lift contacts vertically off of the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jessica
회원 가입일: 10/07/14
150 평판
안내서 1개 작성함
USF Tampa, Team 7-4, Leahy Fall 2014 USF Tampa, Team 7-4, Leahy Fall 2014 회원
USFT-LEAHY-F14S7G4
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 531
