주요 콘텐츠로 건너뛰기
ASUS PadFone X Vibration Motor Replacement
필요한 것
  1. ASUS PadFone X Vibration Motor Replacement, Vibration Motor: 1 단계, 이미지 1/2 ASUS PadFone X Vibration Motor Replacement, Vibration Motor: 1 단계, 이미지 2/2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Vibration Motor Replacement: 2 단계, 이미지 1/2 ASUS PadFone X Vibration Motor Replacement: 2 단계, 이미지 2/2
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Vibration Motor Replacement: 3 단계, 이미지 1/2 ASUS PadFone X Vibration Motor Replacement: 3 단계, 이미지 2/2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Vibration Motor Replacement: 4 단계, 이미지 1/1
    • Using a spudger, pry the vibration motor connector from the motherboard.
  5. ASUS PadFone X Vibration Motor Replacement: 5 단계, 이미지 1/1
    • Gently pry the vibration motor upwards using the spudger.
    • The vibration motor is held down by some adhesive, force might be needed to remove it.
결론
Ryan
회원 가입일: 05/14/12
223 평판
안내서 2개 작성하였습니다
USF Tampa, Team 8-4, Leahy Fall 2014 USF Tampa, Team 8-4, Leahy Fall 2014 회원
USFT-LEAHY-F14S8G4
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
That is not the speaker, that is the motor for the vibrate functions...
The speaker is located in the plastic back of the housing near the camera hole.
tee1331 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 7
전체 시간: 1,306
