주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Padfone X mini Station Front Camera Replacement
필요한 것
  1. ASUS Padfone X mini Station Front Camera Replacement, Front Camera Lens: 1 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Front Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  3. ASUS Padfone X mini Station Front Camera Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to remove cover sticker on the dock station.
  4. ASUS Padfone X mini Station Front Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove the six 0.6mm screws that secure the dock station case to the motherboard.
  5. ASUS Padfone X mini Station Front Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Flip the device upwards.
    • Gently push the right side of motherboard down away from the dock station.
    • Do not push the motherboard so hard as it is still attached to a connector. Excessive force applied might cause external damage to it.
  6. ASUS Padfone X mini Station Front Camera Replacement: 6 단계, 이미지 2개 중 1개 ASUS Padfone X mini Station Front Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Use tweezers to detach the camera from the motherboard.
결론
작성자
2다른 기여자 명과 함께
Nuri Syahirah Mohd Safian
회원 가입일: 10/26/18
133 평판
안내서 1개를 작성함
UMass Dartmouth, Team S2-G7, Peak Fall 2018 UMass Dartmouth, Team S2-G7, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G7
3 회원들
안내서 4개를 작성함
1가이드 댓글
I can not get my back off the device at the top of it it doesn't want to complete separate.
Jannell A McDonald - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 5
전체 시간: 255
