주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Padfone X mini Station Speaker Replacement
필요한 것
  1. ASUS Padfone X mini Station Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Speaker Replacement: 2 단계, 이미지 2개 중 1개 ASUS Padfone X mini Station Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. ASUS Padfone X mini Station Speaker Replacement: 3 단계, 이미지 3개 중 1개 ASUS Padfone X mini Station Speaker Replacement: 3 단계, 이미지 3개 중 2개 ASUS Padfone X mini Station Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
  4. ASUS Padfone X mini Station Speaker Replacement, Speaker: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  5. ASUS Padfone X mini Station Speaker Replacement: 5 단계, 이미지 3개 중 1개 ASUS Padfone X mini Station Speaker Replacement: 5 단계, 이미지 3개 중 2개 ASUS Padfone X mini Station Speaker Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to remove the three pieces of tape that are covering the metal.
    • Insert the metal spudger beneath the speaker case and wedge it upwards to remove speaker case from the device body.
  6. ASUS Padfone X mini Station Speaker Replacement: 6 단계, 이미지 2개 중 1개 ASUS Padfone X mini Station Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Use tweezers to detach the connecter from the motherboard.
결론
작성자
3다른 기여자 명과 함께
Alexzander Pastore
회원 가입일: 10/26/18
389 평판
안내서 3개를 작성함
UMass Dartmouth, Team S2-G7, Peak Fall 2018 UMass Dartmouth, Team S2-G7, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G7
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 261
