주요 콘텐츠로 건너뛰기
ASUS Portable AiO PT2001 Back Panel Replacement
필요한 것
  1. ASUS Portable AiO PT2001 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/3 ASUS Portable AiO PT2001 Back Panel Replacement, Back Panel: 1 단계, 이미지 2/3 ASUS Portable AiO PT2001 Back Panel Replacement, Back Panel: 1 단계, 이미지 3/3
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
  2. ASUS Portable AiO PT2001 Back Panel Replacement: 2 단계, 이미지 1/3 ASUS Portable AiO PT2001 Back Panel Replacement: 2 단계, 이미지 2/3 ASUS Portable AiO PT2001 Back Panel Replacement: 2 단계, 이미지 3/3
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
  3. ASUS Portable AiO PT2001 Back Panel Replacement: 3 단계, 이미지 1/3 ASUS Portable AiO PT2001 Back Panel Replacement: 3 단계, 이미지 2/3 ASUS Portable AiO PT2001 Back Panel Replacement: 3 단계, 이미지 3/3
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Vinu Weerasinghe
회원 가입일: 04/16/18
381 평판
안내서 2개 작성하였습니다
Cal Poly, Team S17-G5, Livingston Spring 2018 Cal Poly, Team S17-G5, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G5
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,172
