주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Portable AiO PT2001 Motherboard Replacement
필요한 것
  1. ASUS Portable AiO PT2001 Motherboard Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 ASUS Portable AiO PT2001 Motherboard Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 ASUS Portable AiO PT2001 Motherboard Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
  2. ASUS Portable AiO PT2001 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 ASUS Portable AiO PT2001 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 ASUS Portable AiO PT2001 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
  3. ASUS Portable AiO PT2001 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 ASUS Portable AiO PT2001 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 ASUS Portable AiO PT2001 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
  4. ASUS Portable AiO PT2001 Motherboard Replacement, RAM: 4 단계, 이미지 2개 중 1개 ASUS Portable AiO PT2001 Motherboard Replacement, RAM: 4 단계, 이미지 2개 중 2개
    • Peel off the tape attaching the metal enclosure to the heat sink.
    • Lift the metal enclosure off of the motherboard.
  5. ASUS Portable AiO PT2001 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 ASUS Portable AiO PT2001 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 ASUS Portable AiO PT2001 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the jaws of the white plastic frame apart. This will pop the front of the RAM up.
    • Gently lift the front edge of the RAM.
    • Pull the RAM out and up.
  6. ASUS Portable AiO PT2001 Motherboard Replacement, Wireless Card: 6 단계, 이미지 1개 중 1개
    • The wireless card is on the corner of the motherboard next to the speaker. Remove the black tape to reveal the wireless card.
  7. ASUS Portable AiO PT2001 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 ASUS Portable AiO PT2001 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the 3.5 mm Phillips #1 screw from the wireless card.
    • Remove the connectors by pulling straight up on their ends.
  8. ASUS Portable AiO PT2001 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 ASUS Portable AiO PT2001 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the wireless card from the casing by lifting up then pulling out.
    • The wireless card is fragile. Be careful when pulling it out of the casing.
  9. ASUS Portable AiO PT2001 Motherboard Replacement, Heat Sink and Fan: 9 단계, 이미지 2개 중 1개 ASUS Portable AiO PT2001 Motherboard Replacement, Heat Sink and Fan: 9 단계, 이미지 2개 중 2개
    • Remove the tape attached to the heat sink and the metal enclosure.
    • Lift the metal enclosure off.
  10. ASUS Portable AiO PT2001 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the four 3.0 mm Phillips #1 screws attaching the heat sink to the motherboard.
    • Remove the three 4.0 mm Phillips #1 screws connecting the fan to the device.
  11. ASUS Portable AiO PT2001 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the heat sink and fan assembly off of the device.
    • When putting the heat sink back into place, reapply thermal paste to the underside of the heat sink where it rests on the motherboard.
  12. ASUS Portable AiO PT2001 Motherboard Replacement, Motherboard: 12 단계, 이미지 3개 중 1개 ASUS Portable AiO PT2001 Motherboard Replacement, Motherboard: 12 단계, 이미지 3개 중 2개 ASUS Portable AiO PT2001 Motherboard Replacement, Motherboard: 12 단계, 이미지 3개 중 3개
    • Flip up the locking mechanism and disconnect the three cables using a nylon spudger.
    • Disconnect two more cables by pulling back on the cable using a nylon spudger.
    • Disconnect the battery cable by pulling up on the black connector.
  13. ASUS Portable AiO PT2001 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 ASUS Portable AiO PT2001 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the four-5mm screws that hold the hard drive enclosure to the PC.
    • Pull the hard drive away from the motherboard and set it aside.
  14. ASUS Portable AiO PT2001 Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the nine-3.5mm screws located at the sides of the motherboard.
    • The screws are denoted by white triangles.
  15. ASUS Portable AiO PT2001 Motherboard Replacement: 15 단계, 이미지 1개 중 1개
    • Lift the motherboard off the motherboard standoffs.
    • Remembering the position of the motherboard standoffs makes it easier to position the motherboard when placing it back in the PC.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Vinu Weerasinghe
회원 가입일: 04/16/18
381 평판
안내서 2개를 작성함
Cal Poly, Team S17-G5, Livingston Spring 2018 Cal Poly, Team S17-G5, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G5
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 25
전체 시간: 1,138
