주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Portable AiO PT2001 Wireless Card Replacement
필요한 것
  1. ASUS Portable AiO PT2001 Wireless Card Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 ASUS Portable AiO PT2001 Wireless Card Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 ASUS Portable AiO PT2001 Wireless Card Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
    댓글 쓰기
  2. ASUS Portable AiO PT2001 Wireless Card Replacement: 2 단계, 이미지 3개 중 1개 ASUS Portable AiO PT2001 Wireless Card Replacement: 2 단계, 이미지 3개 중 2개 ASUS Portable AiO PT2001 Wireless Card Replacement: 2 단계, 이미지 3개 중 3개
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
    댓글 쓰기
  3. ASUS Portable AiO PT2001 Wireless Card Replacement: 3 단계, 이미지 3개 중 1개 ASUS Portable AiO PT2001 Wireless Card Replacement: 3 단계, 이미지 3개 중 2개 ASUS Portable AiO PT2001 Wireless Card Replacement: 3 단계, 이미지 3개 중 3개
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
    댓글 쓰기
  4. ASUS Portable AiO PT2001 Wireless Card Replacement, Wireless Card: 4 단계, 이미지 1개 중 1개
    • The wireless card is on the corner of the motherboard next to the speaker. Remove the black tape to reveal the wireless card.
    댓글 쓰기
  5. ASUS Portable AiO PT2001 Wireless Card Replacement: 5 단계, 이미지 2개 중 1개 ASUS Portable AiO PT2001 Wireless Card Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the 3.5 mm Phillips #1 screw from the wireless card.
    • Remove the connectors by pulling straight up on their ends.
    댓글 쓰기
  6. ASUS Portable AiO PT2001 Wireless Card Replacement: 6 단계, 이미지 2개 중 1개 ASUS Portable AiO PT2001 Wireless Card Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the wireless card from the casing by lifting up then pulling out.
    • The wireless card is fragile. Be careful when pulling it out of the casing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Erich Fenczik Warnock
회원 가입일: 04/17/18
193 평판
안내서 2개를 작성함
Cal Poly, Team S17-G5, Livingston Spring 2018 Cal Poly, Team S17-G5, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G5
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 35
전체 시간: 950
