주요 콘텐츠로 건너뛰기
ASUS Q302L Fan Replacement
필요한 것
  1. ASUS Q302L Fan Replacement, Back Case: 1 단계, 이미지 1/1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Fan Replacement: 2 단계, 이미지 1/3 ASUS Q302L Fan Replacement: 2 단계, 이미지 2/3 ASUS Q302L Fan Replacement: 2 단계, 이미지 3/3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Fan Replacement: 3 단계, 이미지 1/1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Fan Replacement, Fan: 4 단계, 이미지 1/2 ASUS Q302L Fan Replacement, Fan: 4 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
    • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
  5. ASUS Q302L Fan Replacement: 5 단계, 이미지 1/3 ASUS Q302L Fan Replacement: 5 단계, 이미지 2/3 ASUS Q302L Fan Replacement: 5 단계, 이미지 3/3
    • Gently wedge two plastic prying tools on both sides of the black part of the connector.
    • Carefully pull out the connector from its socket.
  6. ASUS Q302L Fan Replacement: 6 단계, 이미지 1/2 ASUS Q302L Fan Replacement: 6 단계, 이미지 2/2
    • Once all screws and the connector are removed, you can safely pull the fan out of its place.
결론
Kerolus Gerges
회원 가입일: 03/02/17
219 평판
안내서 2개 작성하였습니다
USF Tampa, Team S13-G4, Cagle Spring 2017 USF Tampa, Team S13-G4, Cagle Spring 2017 회원
USFT-CAGLE-S17S13G4
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 784
