주요 콘텐츠로 건너뛰기
ASUS Q324UA-BHI7T17 CPU Fan Replacement
필요한 것
  1. ASUS Q324UA-BHI7T17 CPU Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Remove all 10 Phillips screws on the backplate.
    • All 10 screws are 0.55 inches and 20 mm in diameter.
  2. ASUS Q324UA-BHI7T17 CPU Fan Replacement: 2 단계, 이미지 1/2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: 2 단계, 이미지 2/2
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 CPU Fan Replacement: 3 단계, 이미지 1/1
    • Locate the battery near the bottom.
  4. ASUS Q324UA-BHI7T17 CPU Fan Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
    • Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
  5. ASUS Q324UA-BHI7T17 CPU Fan Replacement: 5 단계, 이미지 1/2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: 5 단계, 이미지 2/2
    • Remove the six screws holding in the battery with a Phillips #0 screwdriver.
    • Once battery is lifted out and removed, proper dispose of the old battery.
    • Each screw is 0.5 cm in length and 0.5 cm in diameter.
  6. ASUS Q324UA-BHI7T17 CPU Fan Replacement, CPU Fan: 6 단계, 이미지 1/2 ASUS Q324UA-BHI7T17 CPU Fan Replacement, CPU Fan: 6 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver remove the six screws holding the CPU Fan and Heatsink in place.
    • All six screws are 0.4 cm in length and have a 0.5 cm head diameter.
  7. ASUS Q324UA-BHI7T17 CPU Fan Replacement: 7 단계, 이미지 1/2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Next, carefully remove the sliding connector that connect the CPU Fan and the laptop together using the tweezers.
  8. ASUS Q324UA-BHI7T17 CPU Fan Replacement: 8 단계, 이미지 1/1
    • Remove the CPU Fan and Heatsink by simply lifting upwards.
결론
Scott Santiago
회원 가입일: 10/17/17
534 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S1-G1, Simcock Fall 2017 UMass Dartmouth, Team S1-G1, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 23
전체 시간: 1,082
