주요 콘텐츠로 건너뛰기
ASUS Q324UA-BHI7T17 Keyboard Keys Replacement
필요한 것
  1. ASUS Q324UA-BHI7T17 Keyboard Keys Replacement, Keyboard Keys: 1 단계, 이미지 1/2 ASUS Q324UA-BHI7T17 Keyboard Keys Replacement, Keyboard Keys: 1 단계, 이미지 2/2
    • First, insert the opening tool, between the key cap and the hinge and push up gently.
    • The key should pop out easily.
  2. ASUS Q324UA-BHI7T17 Keyboard Keys Replacement: 2 단계, 이미지 1/2 ASUS Q324UA-BHI7T17 Keyboard Keys Replacement: 2 단계, 이미지 2/2
    • Place, the flat head screwdriver between the two parts of the plastic hinge, and turn it a little so the first part pops out.
    • You can start on either side, either the right or the left it does not matter, just make sure to do both sides.
  3. ASUS Q324UA-BHI7T17 Keyboard Keys Replacement: 3 단계, 이미지 1/2 ASUS Q324UA-BHI7T17 Keyboard Keys Replacement: 3 단계, 이미지 2/2
    • Next remove the last plastic piece from the keyboard, and properly dispose of all three parts.
결론
Scott Santiago
회원 가입일: 10/17/17
534 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S1-G1, Simcock Fall 2017 UMass Dartmouth, Team S1-G1, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 514
