주요 콘텐츠로 건너뛰기
ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement
필요한 것
  1. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement, Battery: 1 단계, 이미지 1/1
    • Remove all 10 Phillips screws on the backplate.
    • All 10 screws are 0.55 inches and 20 mm in diameter.
  2. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 2 단계, 이미지 1/2 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 2 단계, 이미지 2/2
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 3 단계, 이미지 1/1
    • Locate the battery near the bottom.
  4. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
    • Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
  5. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 5 단계, 이미지 1/2 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 5 단계, 이미지 2/2
    • Remove the six screws holding in the battery with a Phillips #0 screwdriver.
    • Once battery is lifted out and removed, proper dispose of the old battery.
    • Each screw is 0.5 cm in length and 0.5 cm in diameter.
  6. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement, Power & Volume Button PCB Board: 6 단계, 이미지 1/1
    • Remove the screw holding the Power chip in place and remove it using a Phillips head #0 screw driver.
    • Screw length is 0.5 cm in length and 0.5 cm in diameter
  7. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 7 단계, 이미지 1/3 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 7 단계, 이미지 2/3 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 7 단계, 이미지 3/3
    • Locate the ribbon connector connecting the power chip to the mother board.
    • Simply lift up the black component and the ribbon connector should be released, then the power chip should pop out easily.
    • Discard of the old power chip properly.
결론
Scott Santiago
회원 가입일: 10/17/17
534 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S1-G1, Simcock Fall 2017 UMass Dartmouth, Team S1-G1, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 16
전체 시간: 665
