주요 콘텐츠로 건너뛰기
ASUS Q324UA-BHI7T17 Track Pad Replacement
필요한 것
  1. ASUS Q324UA-BHI7T17 Track Pad Replacement, Track Pad: 1 단계, 이미지 1/2 ASUS Q324UA-BHI7T17 Track Pad Replacement, Track Pad: 1 단계, 이미지 2/2
    • Remove all ten 5mm screws from the backplate using a Phillips #0 Screwdriver.
  2. ASUS Q324UA-BHI7T17 Track Pad Replacement: 2 단계, 이미지 1/1
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 Track Pad Replacement: 3 단계, 이미지 1/1
    • Lift up the back plate and slide it to the back of the computer to remove.
  4. ASUS Q324UA-BHI7T17 Track Pad Replacement: 4 단계, 이미지 1/3 ASUS Q324UA-BHI7T17 Track Pad Replacement: 4 단계, 이미지 2/3 ASUS Q324UA-BHI7T17 Track Pad Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Disconnect the battery from the laptop in the upper left side of the battery, using tweezers.
  5. ASUS Q324UA-BHI7T17 Track Pad Replacement: 5 단계, 이미지 1/1
    • Remove the six 5 mm screws holding the battery using a Phillips #0 screwdriver.
  6. ASUS Q324UA-BHI7T17 Track Pad Replacement: 6 단계, 이미지 1/1
    • Carefully remove the battery using the plastic opening tool.
  7. ASUS Q324UA-BHI7T17 Track Pad Replacement: 7 단계, 이미지 1/3 ASUS Q324UA-BHI7T17 Track Pad Replacement: 7 단계, 이미지 2/3 ASUS Q324UA-BHI7T17 Track Pad Replacement: 7 단계, 이미지 3/3
    • Disconnect the trackpad from the motherboard using tweezers.
    • The white tab flips up.
  8. ASUS Q324UA-BHI7T17 Track Pad Replacement: 8 단계, 이미지 1/2 ASUS Q324UA-BHI7T17 Track Pad Replacement: 8 단계, 이미지 2/2
    • Remove the two 5mm screws holding in the trackpad using a Phillips #0 screwdriver.
  9. ASUS Q324UA-BHI7T17 Track Pad Replacement: 9 단계, 이미지 1/2 ASUS Q324UA-BHI7T17 Track Pad Replacement: 9 단계, 이미지 2/2
    • Remove adhesive tape tethering the trackpad to the motherboard with tweezers.
  10. ASUS Q324UA-BHI7T17 Track Pad Replacement: 10 단계, 이미지 1/3 ASUS Q324UA-BHI7T17 Track Pad Replacement: 10 단계, 이미지 2/3 ASUS Q324UA-BHI7T17 Track Pad Replacement: 10 단계, 이미지 3/3
    • Carefully remove the trackpad using the plastic opening tool.
    • Lift up and side track toward the back of the computer to remove.
결론
Gabriel survance
회원 가입일: 04/01/19
343 평판
안내서 2개 작성하였습니다
IUPUI, Team S2-G2, Harley Spring 2019 IUPUI, Team S2-G2, Harley Spring 2019 회원
IUPUI-HARLEY-S19S2G2
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 186
