주요 콘텐츠로 건너뛰기
ASUS Q400A-BHI7N03 Battery Replacement
  1. ASUS Q400A-BHI7N03 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop over so that it is upside down.
    • The slightly raised area is the battery.
    • Orient the laptop so that the battery is away from you.
  2. ASUS Q400A-BHI7N03 Battery Replacement: 2 단계, 이미지 1/1
    • In the top right corner, push the tab to the right to the unlocked position.
  3. ASUS Q400A-BHI7N03 Battery Replacement: 3 단계, 이미지 1/2 ASUS Q400A-BHI7N03 Battery Replacement: 3 단계, 이미지 2/2
    • Find the tab in the top left corner. With one finger, pull the tab to the left to the unlocked position.
    • While holding this tab in the unlocked position, gently pull the battery away from you.
결론
To reinsert your battery, follow these instructions in reverse order. Remember to re-lock the tab in step 2.
Matthew Gold
회원 가입일: 01/19/17
401 평판
안내서 4개 작성하였습니다
UC Davis, Team 1-4, Rodger Winter 2017 UC Davis, Team 1-4, Rodger Winter 2017 회원
UCD-RODGER-W17S1G4
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 697
