주요 콘텐츠로 건너뛰기
ASUS Q400A-BHI7N03 RAM Replacement
필요한 것
  1. ASUS Q400A-BHI7N03 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop over so that it is upside down.
    • The slightly raised area is the battery.
    • Orient the laptop so that the battery is away from you.
  2. ASUS Q400A-BHI7N03 RAM Replacement: 2 단계, 이미지 1/1
    • In the top right corner, push the tab to the right to the unlocked position.
  3. ASUS Q400A-BHI7N03 RAM Replacement: 3 단계, 이미지 1/2 ASUS Q400A-BHI7N03 RAM Replacement: 3 단계, 이미지 2/2
    • Find the tab in the top left corner. With one finger, pull the tab to the left to the unlocked position.
    • While holding this tab in the unlocked position, gently pull the battery away from you.
  4. ASUS Q400A-BHI7N03 RAM Replacement, RAM: 4 단계, 이미지 1/1
    • Flip the laptop so that it is upside down and locate a screw near the middle of the laptop. Remove the 8 mm PH0 screw.
  5. ASUS Q400A-BHI7N03 RAM Replacement: 5 단계, 이미지 1/2 ASUS Q400A-BHI7N03 RAM Replacement: 5 단계, 이미지 2/2
    • Use a spudger or opening tool to remove the L shaped section of the back cover.
    • To avoid breaking the plastic, alternate the sides where you pry.
  6. ASUS Q400A-BHI7N03 RAM Replacement: 6 단계, 이미지 1/3 ASUS Q400A-BHI7N03 RAM Replacement: 6 단계, 이미지 2/3 ASUS Q400A-BHI7N03 RAM Replacement: 6 단계, 이미지 3/3
    • The RAM is located in the top of the section you uncovered.
    • Identify the two metal tabs on both sides of the RAM.
    • Gently push both tabs outwards at the same time. The RAM will pop up.
    • Carefully pull the RAM out.
  7. ASUS Q400A-BHI7N03 RAM Replacement: 7 단계, 이미지 1/2 ASUS Q400A-BHI7N03 RAM Replacement: 7 단계, 이미지 2/2
    • To put RAM back in, lineup the RAM with the plastic holder.
    • Slide it into the slot at a 30 degree angle and push down until it clicks into place.
결론
Matthew Gold
회원 가입일: 01/19/17
401 평판
안내서 4개 작성하였습니다
UC Davis, Team 1-4, Rodger Winter 2017 UC Davis, Team 1-4, Rodger Winter 2017 회원
UCD-RODGER-W17S1G4
5 회원들
안내서 4개 작성하였습니다
댓글 2개
Hello there ! I got a question. What type of ram should I buy to replace my Asus ? I trying to upgrade to 16 gb
rockygc1985 - 답글
If I only have 1 stick of 4gb, and assuming I won't be getting more, does it matter which slot I place it? Top or bottom (closer to the motherboard) ? Thanks ahead of time!
John H - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 11
전체 시간: 682
